I just test nRF52840 DK with ble_app_att_mtu_throughput_pca10040_s132 example. I know BOARD_TESTER transmits 1024 dummy kbytes to BOARD_DUMMY. I want to replace dummy byte by my data. How can I do this? Thanks for your help!!!
Hi Focus,
If you have a look at the test_run() function in main.c you can find that we call nrf_ble_amts_notif_spam() which then call char_notification_send(). Inside char_notification_send() you can find we continuously send dummy data[256] there. You can replace the dummy "data" with your own data. Note that you have to check for the return code of sd_ble_gatts_hvx() to make sure the data is queued properly or not or if CCCD is enabled or not.
Once we've set the transmission data as you said, where do we then read the received data?
Hi greyed,
I answered your question here.
