write long characteristic
I am trying to implement write long characteristic between master control panel and PCA10001 board. here is my code
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t                         err_code;
static ble_gap_evt_auth_status_t m_auth_status;
ble_gap_enc_info_t *             p_enc_info;
ble_gatts_evt_write_t          * p_evt_write;
uint8_t                          inData;
uint16_t                         inDataLen;
uint8_t buffer[30];
    case BLE_GAP_EVT_CONNECTED:
        nrf_gpio_pin_set(CONNECTED_LED_PIN_NO);
        nrf_gpio_pin_clear(ADVERTISING_LED_PIN_NO);
        nrf_gpio_pin_clear(CONNECTED_LED_PIN_NO);
        advertising_start();
        err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                               BLE_GAP_SEC_STATUS_SUCCESS,
                                               &m_sec_params);
        err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0);
    case BLE_GAP_EVT_AUTH_STATUS:
        m_auth_status = p_ble_evt->evt.gap_evt.params.auth_status;
    case BLE_GAP_EVT_SEC_INFO_REQUEST:
        p_enc_info = &m_auth_status.periph_keys.enc_info;
        if (p_enc_info->div == p_ble_evt->evt.gap_evt.params.sec_info_request.div)
            err_code = sd_ble_gap_sec_info_reply(m_conn_handle, p_enc_info, NULL);
            // No keys found for this device
            err_code = sd_ble_gap_sec_info_reply(m_conn_handle, NULL, NULL);
    case BLE_GAP_EVT_TIMEOUT:
        if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISEMENT)
            // Configure buttons with sense level low as wakeup source.
            nrf_gpio_cfg_sense_input(WAKEUP_BUTTON_PIN,
                                     BUTTON_PULL,
                                     NRF_GPIO_PIN_SENSE_LOW);
            // Go to system-off mode (this function will not return; wakeup will cause a reset)
			case BLE_EVT_USER_MEM_REQUEST:
              sprintf((char *)buffer, "memory requested, 0x%d\r\n", p_ble_evt->evt.common_evt.params.user_mem_request.type);
              simple_uart_putstring(buffer);
					if(p_ble_evt->evt.common_evt.params.user_mem_request.type ==BLE_USER_MEM_TYPE_GATTS_QUEUED_WRITES)
						//m_user_mem_release.mem_block !! Has to be set
						m_mem_block.p_mem = &m_mem_queue[0];
						m_mem_block.len = MEM_BLOCK_SIZE;
						err_code = sd_ble_user_mem_reply(m_conn_handle , &m_mem_block);
			case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
              simple_uart_putstring("authorize\r\n");
					m_rw_authorize_reply.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
					m_rw_authorize_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
					if(p_ble_evt->evt.gatts_evt.params.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)
						err_code =  sd_ble_gatts_rw_authorize_reply(m_conn_handle,&m_rw_authorize_reply);
					} else if ( p_ble_evt->evt.gatts_evt.params.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
			case BLE_EVT_USER_MEM_RELEASE:
           simple_uart_putstring("release\r\n");
				if (p_ble_evt->evt.common_evt.params.user_mem_release.mem_block.p_mem == m_mem_block.p_mem)
					// will fail if mem block is not set previously
					// Do something
        case BLE_GATTS_EVT_WRITE:
           //sprintf((char *)buffer, "event write\r\n");
           //sprintf((char *)buffer, "<<0x%lx 0x%lx>>\r\n", p_ble_evt->evt.gatts_evt.params.write.len, *(uint8_t *)p_ble_evt->evt.gatts_evt.params.write.data);
           p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
           if(p_evt_write->op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
              if(*((uint16_t *)m_mem_block.p_mem) == m_nus.tx_handles.value_handle)
                 inData = 0;
                 inDataLen = sizeof(uint8_t);
                 sd_ble_gatts_value_get(m_conn_handle, 0, &inDataLen, &inData );
                 sprintf((char *)buffer, "||0x%lx||", inData);
                 simple_uart_putstring("\r\n");
        // No implementation needed.
simple_uart_put(m_mem_queue[0]);
simple_uart_put(m_mem_queue[1]);
simple_uart_put(m_mem_queue[2]);
simple_uart_put(m_mem_queue[3]);
sprintf((char *)buffer, "\r\n Event:0x%lx\r\n", p_ble_evt->header.evt_id);
I am using MCP to write long a text string. but at the PCA10001 side when I parse m_mem_queue to check the data there is noting inside. futhermore I notice that I never get into the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST here is the output of my console
Start...
Event:0x10
Event:0x52
Event:0x50
memory requested, 0x1
Event:0x2
||0x0||
Event:0x50
release
Event:0x3
