app_timer_start error code 4
What does error code 4 mean? I am looking through the documentation for the error code number to string translation.
Why is starting a timer causing the error code 4?
The timer is setup as follows, it was previous 10, which should have been more than enough.
#define APP_TIMER_PRESCALER             0
#define APP_TIMER_MAX_TIMERS           13
#define APP_TIMER_OP_QUEUE_SIZE        13
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
err_code = app_timer_create(&m_led_on_timer_id, APP_TIMER_MODE_SINGLE_SHOT, led_on_timeout_handler);
Error code 4, occurs trying to start the led timer. void led_on_start(void) { uint32_t err_code; // Start led timers. err_code = app_timer_start(m_led_on_timer_id, led_t_on, NULL); APP_ERROR_CHECK(err_code); }
  • Just type NRF_ERROR_INVALID_PARAM into the search box in the documentation to find ..
    #define 	NRF_ERROR_NO_MEM   (NRF_ERROR_BASE_NUM + 4)
     	No Memory for operation.
    and in the timer reference ..
    NRF_ERROR_NO_MEM	Timer operations queue was full.
    so your operations queue is full. Why .. that you need to figure out. You could just put a breakpoing on the app_timer_start() function see how many times you're calling it.
  • Ok thank you very much.
