Hi There,
I am doing current measurements on the nrf52840 in sleep mode with no RAM retention and I am getting different values based on how I take the measurements. Please see the various methods and resulted below.
Using an amp meter in series with P22 - SW10 = On | SW6 = nRF Only | VP21 = 3.3V
13.2 micro amp -
Using and amp meter in series with P22 and power from USB header J2 - SW10 = off | SW6 = nrf ONly 1.3 micro amp
Using and amp meter in series with P21 - SW10 = On | SW6 = nRF Only | VP21 = 3.3V 1.46 micro amp
Using and amp meter in series with P21 - SW10 = On | SW6 = default | VP21 = 3.3V 0.1 micro amp
Using the PPK with jumper SB40 open 33 micro amp
Can you please help me to understand why these numbers are so different. I believe that method 2 above is probably the correct value, even though it does seem a bit high. Isn't the nRF52840 supposed to draw around 500 nA in sleep mode? Your help would be much appreciated.
