ADC + ble connection
I am using nrf51_sdk_v6_0_0_43681 and s110_nrf51822_7.0.01 wiht nrf51822, and I modifiy code based on ble_app_uart.
Here I am trying to launch a continous ADC sample with a repeated mode timer, the timer interval is 1ms or 2ms or 4ms. Meanwhile I disconnect and conect my cellphone(Samsumg Notes 3) with nrf51822 board. Serval times later, I found that the nrf51822 system should be crashed,because my local uart can not be input and ble has no advertising.
What is the problem?
Thanks
Frank
Edit: Format + Added commas between tags
  • Hi Frank
    Take a look at this example code on Github where the ADC is continuously sampling when the softevice is advertising/connected. As you describe you problem, I suspect the problem might be the priority of your ADC interrupt handler, you must explicitly set the priority when you initialize the ADC
  • Hi Stefan, Great thanks for your answer.Here I found that continously ADC sampling is not the root cause of system crash. I have an function xxx_process in main loop runtine as below. It is a complicated algorithm, sometimes it will take about 2 second to finish it. When algorithm is running, and I connect/disconnect the board with my cellphone, it will cause system crash. Here I want to know if I can disable ble response before algorithm running and enable ble response after algorithm finish.
    main() { ..... //initialization for (;;) { xxx_process(); power_manage();
    Thanks Frank
  • You could disconnect before the algorithm executes, then advertise when it finishes in order to connect again. You can also set the slave latency to a relatively high number so that the nRF51 device is not required to respond to the phone for a number of connection events. What I am curious to know however, why is the device crashing when you press connect/disconnect. The code that you execute in the main function has lowest priority and should not interrupt any softdevice activity.
  • Hi Stefan, I think that I have found the key problem. Nrf51822 has problem with process dyadic array. Please see xxx_process() as below, it is just a test case. If I enable dyadic array, the system will crash when connecting/disconnecting, if I disable dyadic array, it should be OK. I think that it should be a bug. Please check and confirm it. void xxx_process(void) { long N,M; long i,j,s,r,t; float temp; long k1,k2; float u,v,w; float Re[256]; float Am[256]; float Im[256][256]; float pi = 3.1416;
    for(i=0;i<256;i++) { for(j=0;j<256;j++) { Re[i]=i; Am[i]=i; //Im[i][j]=j; } }
    for(i = 0; i<256;i++) { for(j = 0; j<20000;j++) { u = Re[i]cos(2jpi/256)+ Am[i]sin(2jpi/256); v = Re[i]cos(2jpi/256)- Am[i]sin(2jpi/256);
    	 //w = sqrt(u*u+v*v);
    	 w = sqrt(u*u+v*v)+Im[i][j];
    } main() { ..... //initialization for (;;) { xxx_process(); nrf_delay_ms(5); power_manage();
