sdkconfig.txtmainc.txt(/attachment/6fb97103178e9eb2c30302351e63ce8f)Can you please tell whether i follow the the entire tutorial as in the link or just the first step for SDK 12.2 SES. Even if i use the first step, i need the CMSIS wizard that uses Java tool to modify the functionality in sdkconfig.h to enable logging through the RTT viewer.
But somehow there is a problem with opening the .jar file, since Java tool is not working for my windows.
Is there an alternative way to modify the sdkconfig.h, not manually, as there are chances of errors coming up if i change it myself, then there will be further problems
