Plotting the MPU Accelerometer values in real time
Hi..! Friends..! I am trying to detect the number of steps on accelerometer. For which I want to Plot the accelerometer values in real time (with minimum rate 50values/sec) such that I can analyse the data while walking.
The ways in my mind are:-
  1. Plotting on keil while debugging using logic analyzer but I am not able to implement
  2. In UART Problem is the values printing are less than 50.
please anyone tell how can I solve the problem code is i.e. want to plot the l_a[i] variable of main loop
int main()
	uint32_t err_code;
    bool erase_bonds;
		int i=0;
		long count=0;
		uint8_t id;
		float l_xo,l_a[17];
	  float s;
		float put_1,put_2,put_3,put_4,put_5,put_6,put_7,put_8,put_9,put_10,put_11,put_12,put_13,put_14,put_15,sum_5;
		int fre_count=1;
    // Initialize
    timers_init();
		const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          APP_UART_FLOW_CONTROL_DISABLED,
          false,
          UART_BAUDRATE_BAUDRATE_Baud9600
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOW,
                         err_code);
		twi_master_init();
    ble_stack_init();
    device_manager_init(erase_bonds);
 //   gap_params_init();
 //   advertising_init();
    conn_params_init();
		mpu6050_init(0x68);
	/*if(mpu6050_init(0x68) == false)
		printf("mpu6050 init fail\r\n");
	mpu6050_register_read(0x75U, &id, 1);
   // Start execution.
   // err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
   // APP_ERROR_CHECK(err_code);
    // Enter main loop.
    for (;;)
		     /* power_manage();
			    advertising_init(); // To Update advertising Packets
					MPU6050_ReadAcc( &tem1[0], &tem1[1] , &tem1[2] );
				//MPU6050_ReadGyro(&tem2[0] , &tem2[1] , &tem2[2] );
					now=tem1[0]/10000;
					nrf_delay_ms(1000);
					if(flag2==1)// enters in this if timeout occurs or advertisement stops
								if(flag==0)
									prev=now;
									flag=1;
								if(now!=prev)
									flag2=0;									// stating that advertisement starts
								prev=now;
							MPU6050_ReadAcc( &tem1[0], &tem1[1], &tem1[2] );
							s = tem1[0]*tem1[0]+tem1[1]*tem1[1]+tem1[2]*tem1[2];
							if (fre_count==1)
							   	put_1=s;
							if (fre_count==2)
									put_2=s;
							if (fre_count==3)
									put_3=s;
							if (fre_count==4)
									put_4=s;
							if (fre_count==5)
									put_5=s;
							if (fre_count==6)
									put_6=s;
							if (fre_count==7)
									put_7=s;
							if (fre_count==8)
									put_8=s;
							if (fre_count==9)
									put_9=s;
							if (fre_count==10)
									put_10=s;
							if (fre_count==11)
									put_11=s;
							if (fre_count==12)
									put_12=s;
							if (fre_count==13)
									put_13=s;
							if (fre_count==14)
									put_14=s;
							if (fre_count>=15)
									put_15=s;
							if (fre_count>=15)
										fre_count=16;
										sum_5  = ( put_1+put_2+put_3+put_4+put_5+put_6+put_7+put_8+put_9+put_10+put_11+put_12+put_13+put_14+put_15 )/15;
										l_a[i] = sum_5;
										put_1  = put_2;
										put_2  = put_3;
										put_3  = put_4;
										put_4  = put_5;
										put_5  = put_6;
										put_6  = put_7;
										put_7  = put_8;
										put_8  = put_9;
										put_9  = put_10;
										put_10 = put_11;
										put_11 = put_12;
										put_12 = put_13;
										put_13 = put_14;
										put_14 = put_15;
										printf("%f,  %d,  %d\n",l_a[i],i,count);
										if(i==15)
												i=0;
							 fre_count++;
							 i++;
							 count++;
