To start off here, I'm using a Laird DVK-BL652-1.0, which according to Laird only needs to be re-configured to use the internal oscillator, but is otherwise very similar to the PCA10040. I've done this and run the "blinky" example successfully (blinky lights and all), and made similar changes to the UART example, but can't get it to run.
Initially, I started with the 13.1.0 SDK -> BLE_APP_UART -> PCA10040 -> s132 -> arm5_no_packs (using keil uVision 5), however adding the software packs turned into a constant game of "add the packs, header not found, find/ install the pack it was looking for, repeat" - and it was difficult to build/ flash the soft device and application from separate projects
I eventually got fed up, and used Pack Installer - figuring a pre-made package would be easier. I looked under device, nRF52832_xxAA, and downloaded the ble_app_uart_s132_pca10040 example. Made the changes to the oscillator, batch compiled successfully, flashed the soft device (flash_s132_nrf52_2.0,0-7.aplha), flashed the application... but zero activity from the device. https://flic.kr/p/WvuuWf
Weirdly, after this first attempt, which was based on a build with 0 errors, 0 warnings, the next time around it doesn't show all of the packs, and fails to find nordic_common.h... any help here? https://flic.kr/p/VQ6rTW
I'm mostly using uVision since Nordic shows support.. is there a "better" or more common tool to use? I'm frustrated that I can't get a pre-made example to flash and run.
Thank you, Andrew
Update based on question: I don't get any errors opening the project, and the application layer "nrf52832_xxaa" compiles fine, however when I try to compile the soft device (flash_s132_nrf52_4.0.2_softdevice) I get the following error. Attempting to dig for "nordic_common.h" and adding it to the include path just makes one more header not come up.. and then another, etc. etc. which is what originally led me to try Keil's pack installer. I'm running uVision V5.23.0.0 by the way ......\main.c(53): error: #5: cannot open source input file "nordic_common.h": No such file or directory #include "nordic_common.h" ......\main.c: 0 warnings, 1 error "............\components\softdevice\s132\hex\s132_nrf52_4.0.2_softdevice.hex" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:00
