Why is there a current from 1,5mA bellow 1,8V?
I use a step-down converter(not the integrated one) to generate 1,85V for the nRF51822 in my application.
When the applications starts the output voltage from the converter grows "slow" to 1,85V. I recognized, that the nRF draws some current bellow the 1,75V minimum voltage. So i started to measure: In the screenshot bellow you can see the input voltage in the upper window and the current in mA(not mV!!!) in the under window. image description You can see that from 0,8-1,6V the nRF draws around 0,5mA and from 1,6-1,75V 1,5mA. Then the uC starts up and go to idle. Is there a way to reduce this current without using external components like FETs?
Thank you for your help.
  • There is required operating conditions for nRF51822 described in Product Specification.
    You can see in "7 Operating conditions" there is maximum tR_VDD (Supply rise time (0 V to 1.8 V)) = 60 ms and note:
    The on-chip power-on reset circuitry may not function properly for rise times outside the specified interval.
    So I don't think it's possible to do anything with this problem without additional external components.
  • thank you, perfect,.. and my rise time is faster than 60ms,..:)
