Hello
I wanted to ask what is the correct way to use NRF_LOG_*
functions along with printf (with RETARGET_ENABLED 1
) and normal UART initialized with standard:
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_ENABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
When I enable UART loger backend the application fails on UART init with an error <error> uart: Init failed. id:2 in wrong state
which makes sense as NRF_LOG_INIT already takes over due to #define NRF_LOG_BACKEND_UART_ENABLED 1
setting.
When I disable NRF_LOG_BACKEND_UART_ENABLED
RX on UART works but nothing is printed from printf
even though RETARGET_ENABLED
is enabled.
My questions to the situation encotered are:
I couldn't find a resource on using and properly configuring all the backends, maybe I've missed some chapter in the infocenter?
Can the application and NRF_LOG use different instances of UART but still share the same pins? This would come with the assumption that NRF_LOG only transmits and doesn't receive.
