Hi all,
I am using an NRF52 and SDK 13.0
I have an external device (central) that I am connecting to using my (peripheral) device.
My peer manager set up is
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0
static void peer_manager_init(bool erase_bonds)
ret_code_t err_code;
err_code = pm_init();
TRACE("NUM PEERS %d\r\n", pm_peer_count());
if (erase_bonds)
err_code = pm_peers_delete();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
I can see that when I connect to the external device, I get the following events
- PM_EVT_CONN_SEC_START
- PM_EVT_CONN_SEC_SUCCEEDED peer count 6 peer id 3 procedure PM_LINK_SECURED_PROCEDURE_PAIRING
- PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
Cool, it works. However, when I disconnect the reconnect (by turning the external device off and on) it connects again with the peer count increased by 1.
If I keep turning the device on and off, eventually I no longer see any more peer manager events for the device. This seems to happen after about 10 times. my call to pm_conn_secure returns NRF_SUCCESS
If I turn my device off and on again, the peer count is reset and I see Peer manager events again when connecting to my external device.
My questions are:
- Why does pm_conn_secure stop having an effect after about 10 reconnections?
- Why can I only pair to my external device whereas I can bond to it using an android phone and the NRF Connect app?
- How can I verify if the external device supports bonding?
- Why does it create a new peer every time I reconnect the external device? I imagine its something to do with it only pairing so the LTK etc aren't stored. How could I handle this better?
