I am using SEGGER Studio on MacOSx.
When use the latest mesh SDK, I can run the light_control example and see the debug log in the Debug Terminal of SEGGER Studio.
However, when I use BLE SDK 12.3, I simply cannot see the logs for ble_app_hrs.
I have set:
NRF_LOG_ENABLED 1
NRF_LOG_BACKEND_SERIAL_USES_UART 1
NRF_LOG_BACKEND_SERIAL_USES_RTT 0
I also tried to use RTT instead of UART.
I can set breakpoints and follow through the lines.
I also tried using JLinkExe, JLinkRTTClient, JLinkRTTLogger, JLinkGDBServer, but I just cannot see any debug logs.
Here is the start of the main file of the example:
/**@brief Function for application main entry.
uint32_t err_code;
bool erase_bonds;
NRF_LOG_INFO("START\r\n");
// Initialize.
err_code = NRF_LOG_INIT(NULL);
timers_init();
ble_stack_init();
peer_manager_init(erase_bonds);
if (erase_bonds == true)
NRF_LOG_INFO("Bonds erased!\r\n");
Also tried moving the INIT before the LOG_INFO. Same empty result.
I am using PCA10028, nRF51, s130.
Anything to try other than this?
