I am trying to use a mux change among 3 differential channels. The diff signal then goes through an instrumentation amplifier. The steps I'm using:
switch to ch1, read adc1, wait 3ms switch to ch2, read adc1, wait 3ms switch to ch3, read adc1, wait 3ms
// channel 1
mux_a0 = 0;
mux_a1 = 0;
resultHolder1 = adc1.read_u16();
readValue2[1] = (resultHolder1 >> 8) & 0xFF; // writing top 8 bits
readValue2[0] = resultHolder1 & 0xFF; // writing bottom 8 bits
wait_ms(3);
// channel 2
mux_a0 = 1;
mux_a1 = 0;
resultHolder2 = adc1.read_u16();
readValue3[1] = (resultHolder2 >> 8) & 0xFF; // writing top 8 bits
readValue3[0] = resultHolder2 & 0xFF; // writing bottom 8 bits
wait_ms(3);
// channel 3
resultHolder = adc3.read_u16();
readValue4[1] = (resultHolder >> 8) & 0xFF; // writing top 8 bits
readValue4[0] = resultHolder & 0xFF; // writing bottom 8 bits
// channel 5
mux_a0 = 0;
mux_a1 = 1;
resultHolder3 = adc1.read_u16();
readValue5[1] = (resultHolder3 >> 8) & 0xFF; // writing top 8 bits
readValue5[0] = resultHolder3 & 0xFF; // writing bottom 8 bits
wait_ms(3);
Now the problems I'm facing,
- All channels are showing the same value
- If I connect anything in the last channel all channels shows only that value.
- If I connect ch1 and ch2, all channels add up the values.
- If nothing is connected the adc seems to charge up by itself.
I checked whether the mux is working or not. So, if I use only one channel and don't switch channels the readings seem to be fine. Here's the relevant portion of the circuit:
Am I missing something simple? Any help will be much appreciated.
Thanks, Yasser
