Another programmer developed the nRF52832 source code using IAR. But I want to use Keil uVision.
So please tell me how to convert IAR project file to KEIL uVision Project file. please.
Could you consider using Segger Embedded studio instead? There's a good tutorial for that here. I have asked a colleague about converting an IAR project feil into Keil. It seems simpler to do it the reverse way (i.e. from Keil to IAR), but I haven't found anything the other way. I will get back to you soon. :)
I have googled around a bit and asked some colleagues at the office. There is no easy answer for this problem and I am unsure how difficult it is to import from IAR to Keil. It might be that you will have to create a custom script to convert from IAR to Keil uVision.
