I have no idea how i can install this and use it. I would like if any one can explain in detail. Can you get picture how I can do it? I am using ble_app_hrs_nfc_pairing project in Keil 5.
The instructions to download and compile micro-ecc is documented in this infocenter page. If you are using SDK v13.0.0 or above, you can execute the script build_all.bat (on Windows) to download and compile. Note that you need to install the required software used for compilation, before running the script.
Jørgen
Can you tell by the steps how to get this file "micro_ecc_lib_nrf52.lib"? I can not do this step: "Run make to compile the micro-ecc library". I do not understand how to do this.
I unzip micro-ecc-master.zip in C:\Users\igorbalash\Desktop\I.I.BALASH_2017\nRF5_SDK_14.0.0_3bcc1f7\external\micro-ecc and then rename folder micro-ecc-master to micro-ecc. But when i "make" makefile I have error.
You are not switching directory. Try cd
before the path.
Thanks, it works.
