Read register issue using nrf52 TWI
Hi ,
I have recently bought a nRF5232 PCA10040 development kit and i am trying to interface nRf52832 development kit(Master) with AS3955(slave) over twi. I tested the twi_scanner example and AS3955 responds with correct slave address(i.e 0x50). Now i am trying to read a single register from AS3955. I see that for twi in order to read a register we first have to send SLAVE ADDRESS and REGISTER ADDRESS using nrf_drv_twi_tx driver function and then we have to read using nrf_drv_twi_rx driver function. The AS3955 should respond with register value 0x01(as that is the default value present at REGISTER ADDRESS). But the device does not respond with correct register value and always says 0xFF. Please any help/guidance would be appreciated as i new to this environment and i am stuck on this for a couple of days now. I have attached the code and timing diagram for the slave. image description
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* /SS GPIO for AS3955 (This pin should be kept low for AS3955 in order to activate i2c on the chip)*/
#define SLAVE_SELECT_GPIO 2
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
 #define AS3955_ADDRESS			0x50
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
uint8_t register_address = 0x3E;    //Address of the register to be read
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t sample_data;
    bool detected_device = false;
	nrf_gpio_cfg_output(SLAVE_SELECT_GPIO);
	nrf_gpio_pin_write(SLAVE_SELECT_GPIO, 0);
    twi_init();
	err_code = nrf_drv_twi_tx(&m_twi, AS3955_ADDRESS, &register_address, 1, true);
	if(err_code == NRF_SUCCESS)
		NRF_LOG_INFO("Device Address and Register Address(3 bit mode+ 5 bit reg address sent");
	NRF_LOG_FLUSH();
	err_code = nrf_drv_twi_rx(&m_twi, AS3955_ADDRESS, &sample_data, sizeof(sample_data));
	if (err_code == NRF_SUCCESS)
		NRF_LOG_INFO("The Register read = 0x%x", sample_data);
	NRF_LOG_FLUSH();
	nrf_gpio_pin_write(SLAVE_SELECT_GPIO, 1);
    while (true)
        /* Empty loop. */
