Hello!
I am using the nRF52832 with nRF5_SDK 14.0.0. with a JLink connection. My OS is Ubuntu 16.04.
After placing NRF_LOG_INFO() statements around my code, connecting to the nRF52832_XXAA device with 'JLinkExe', and running 'JLinkRTTClient', only the first log statement would log in my terminal window, not even a statement placed immediately after the first one. I went into my 'sdk_config.h' file and set:
#define NRF_LOG_BACKEND_UART_ENABLED 0
... and then it worked. RTT Client would show the process traveling through my code, and logging expectedly until experiencing a fatal error when it reaches the command 'sd_power_system_off()'. I figured this error made sense, as the RTT client would need CPU to do its job. This isn't my question though. EDIT: after adding 'NRF_LOG_FINAL_FLUSH()' before the 'system_off' the error does not appear anymore.
After changing some code functionality, the JLinkRTTClient again does not log anything. I narrowed the effect down to this single line of code: When changing the command
NRF_LOG_INFO("err_code is: %d", err_code); // error code is 8198
... to:
err_code = sd_nvic_SystemReset();
NRF_LOG_INFO("err_code is: %d", err_code); // nothing logged
... for the purpose of setting up a battery performance test, to run the code over and over until the battery dies, the RTT viewer does not log anything. It pauses after 'Process: JLinkExe' with no further activity. Here is a terminal view showing two separate connection attempts, first after using 'sd_power_system_off()', then a stuck attempt after using 'sd_nvic_SystemReset()':
EDIT: After adding 'NRF_LOG_FINAL_FLUSH();' before the 'SystemReset', the RTT viewer now prints:
<info> a<info> a<inf<info> a<info> a<info> a<info>
... over and over with nothing else. Is it trying to print ' app: [log comment]'? I have no log messages starting with the letter 'a'. What is interrupting its print?
The odd thing is is that the code is actually functioning as expected. I am receiving my BLE signals over and over again, as the test should, but i cant see anything logged to my terminal.
Here are some main.c code snippets: My NRF log_init, and the problematic line switch:
static void log_init(void)
void batt_test_timer_event_handler()
uint32_t err_code;
NRF_LOG_INFO("batt_test_timer expired and is about to reset the system");
err_code = sd_nvic_SystemReset(); // with this line, no logs will appear
//err_code = sd_power_system_off(); // with this instead, logs will appear until the error happening here.
NRF_LOG_INFO("err_code is: %d", err_code); // error value is 8198 with system_off, no error is logged (NOTHING is logged) with SystemReset.
... a skeleton of my main:
// ... variables...
// ... Initialize...
log_init();
NRF_LOG_INFO("in main");
// ...some main stuff...
batt_test_timer_start();
// Enter main loop.
for (;; )
power_manage();
Why does the RTTClient need the error to display its logs? Is the RTT Client waiting for my process to end before it displays its logs? Am I missing a core requirement for using NRF_LOG_INFO()?
Another weird thing: I have three timers set up, totaling maybe 12 seconds. The logging that does occur when that single line of code is switch to 'system_off' appears immediately after I connect to the device. Why is that? I thought it was a 'real-time' viewer, why is it skipping through the timers and displaying everything at once?
Any re-direction, help, ideas, or hints are greatly appreciated!
Thanks!
