timeslot extension never succeed
I have a working scanner and manage to require timeslots with the below timings.
Interval 300ms, scan window 50ms, Timeslot length 10ms.
image description
But when i try to request timeslot extensions as low as 1ms it never works.
nrf_radio_signal_callback_return_param_t * ts_radio_callback(uint8_t signal_type)
	//NRF_LOG_DEBUG("TS_RADIO_CB:%d\r\n", signal_type);
	switch(signal_type)
	case NRF_RADIO_CALLBACK_SIGNAL_TYPE_START: {
		//Start of the timeslot - set up timer interrupt
		// Set up rescheduling
		NRF_TIMER0->INTENSET = (1UL << TIMER_INTENSET_COMPARE0_Pos);
		NRF_TIMER0->CC[0]    = m_slot_length_us - SLOT_SANITY_END_US;
		NVIC_EnableIRQ(TIMER0_IRQn);
		on_ts_start();
		signal_callback_return_param.params.request.p_next = NULL;
		signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_NONE;
	case NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO:
		on_radio_cb();
	case NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0:{
		//Timer interrupt - attempt to increase timeslot length
		if (NRF_TIMER0->EVENTS_COMPARE[0] == 1)
			NRF_TIMER0->EVENTS_COMPARE[0] = 0;
			signal_callback_return_param.params.extend.length_us = SLOT_EXTEND_US;
			signal_callback_return_param.callback_action         = NRF_RADIO_SIGNAL_CALLBACK_ACTION_EXTEND;
	case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED:
		//Extension succeeded, reset timer(configurations still valid since slot length is the same)
		NRF_TIMER0->CC[0]    += SLOT_EXTEND_US;
	case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED:
		//Extension failed, schedule new timeslot at earliest time
		on_ts_stop();
		configure_next_event_earliest();
		signal_callback_return_param.params.request.p_next = &m_timeslot_request;
		signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_REQUEST_AND_END;
		//No implementation needed
	return (&signal_callback_return_param);
complete code here
Many thanks for your clue.
Seb
  • Hi Seb,
    Seems that the issue was at NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED event, that you didn't set the callback_action to NONE.
    I attached here an example in SDK v14 I made (nRF52832, S132 v5.0), it should be similar on SDK v13.
    I use the timer start_timeslot_timeout_handler() to trigger a request for timeslot every second. The timeslot length is 35ms. Timer 0 CC[0] triggered after 30ms.
    The code request more 3 extensions (extension_count). When the last compare event triggered with CLOSE action, I will end the timeslot immediately, result in 120ms length timeslot (instead of 35x4 = 140ms)
    You can monitor pin 18-20 to verify the operation (description of the pins in the main loop)
    ble_app_hrs SDK14- Timeslot.zip
