Initialization:
The softdevice is initialized as in the BLE UART example. The body of the ble_stack_init()
function is identical to the BLE UART example.
SPI is initialized as in the SPI peripheral example, but I have gone over to writing the registers directly, just to verify that there is nothing weird happening with the spi driver. I get the exact same behavior both when using the nrf spi driver and when working with the registers directly.
SPI configuration is as follows:
#define IMU_SCK_PIN 0
#define IMU_MOSI_PIN 1
#define IMU_MISO_PIN 5
NRF_P0->PIN_CNF[IMU_SCK_PIN] = 0b11;
NRF_SPIM0->PSEL.SCK = IMU_SCK_PIN;
NRF_P0->PIN_CNF[IMU_MOSI_PIN] = 0b11;
NRF_SPIM0->PSEL.MOSI = IMU_MOSI_PIN;
NRF_P0->PIN_CNF[IMU_MISO] = 0b00;
NRF_SPIM0->PSEL.MISO = IMU_MISO_PIN;
NRF_SPIM0->FREQUENCY = 0x10000000; // 1Mhz
NRF_SPIM0->CONFIG = 0b000;
NRF_SPIM0->ENABLE = 7;
The transfer is then done as follows:
uint8_t tx_buffer[2] = { 0x80, 0x08 };
uint8_t rx_buffer[2];
NRF_SPIM0->TXD.PTR = (uint32_t) tx_buffer;
NRF_SPIM0->TXD.MAXCNT = 2;
NRF_SPIM0->TXD.LIST = 0;
NRF_SPIM0->RXD.PTR = (uint32_t) rx_buffer;
NRF_SPIM0->RXD.MAXCNT = 2;
NRF_SPIM0->RXD.LIST = 0;
SEGGER_RTT_WriteString(0, "xfer start\r\n");
NRF_SPIM0->EVENTS_END = 0;
NRF_SPIM0->TASKS_START = 1;
while (!NRF_SPIM0->EVENTS_END);
SEGGER_RTT_WriteString(0, "xfer done\r\n");
Case 1:
Everything works as expected when I try to do a SPI transfer before the ble_stack_init();
function has been called called, xfer start
prints, and shortly after xfer done
prints.
EVENTS_START
is asserted immediately when TASKS_START is written to. EVENTS_ENDRX
and EVENTS_ENDTX
are both asserted when the transfer is done, and EVENTS_END
is asserted shortly afterwards. EVENTS_STOPPED
is never asserted, as expected.
Case 2:
However, after ble_stack_init();
has been called, the the EVENTS_END
flag is never asserted, and the while loop never finishes. xfer start
prints, but xfer done
is never printed.
EVENTS_START
is written to, but no other events are asserted. I validate that the interrupt enable register is set to 0 before I start, so I don't think any interrupt could reset the register before the loop checks it.
Additional information:
- My chip is marked N52832 QFAAB0 1701FH
- The board is the NRF52 DK, PCA10040
- Softdevice S132 v5.0.0
- SDK v14
- GCC
Does anyone have any ideas what the problem might be? Hope I didn't do anything way too stupid. I have been struggling with this for a little bit, and it would be really nice to get it sorted out.
