pstorage issues
Hi
I'm trying to use pstorage to save some info (device name, and user info). I've found the following links with examples: infocenter.nordicsemi.com/index.jsp
devzone.nordicsemi.com/.../
Which have code that looks rather straightforward. But I'm having issues, where in some cases it either can only write, or only erase and I can't figure out what is the issue. Here is my code:
Init (in main):
retval = pstorage_init();
param.block_size  = 16;
param.block_count = 1;
param.cb          = store_cb_handler;
pstorage_register(&param, &handle);
pstorage_block_identifier_get(&handle, 0, &block_handle);
Then at some point manually call read, write and clear functions:
Read:
retval = pstorage_load(tempstr, &block_handle, 16, 0);
if (retval == NRF_SUCCESS)
	ble_nus_string_send(&m_nus, tempstr, 16);
    ble_nus_string_send(&m_nus, "no", 3);
Write:
retval =pstorage_store(&block_handle, "Tostertostost000", 16, 0);
    ble_nus_string_send(&m_nus, "ok", 3);
Clear:
pstorage_clear(&block_handle, 16);
So if I use &block_handle clear works, and if I put just &handle then store works. What could be the issue here?
