Questions about the Nor51822 BLE and PWM?
How do you do
Now use the Nordic \ nRF5_SDK_12 2.0 _f012efa \ examples \ ble_peripheral \ ble_app_uart this plus Nordic \ nRF5_SDK_12 2.0 _f012efa \ examples \ peripheral \ pwm_library this routine.
  1. Only PWM operation, use the bluetooth connection will be disconnected after sending data.I ask, is there any way to solve this?
  2. There is a problem is PWM Pwm1_cfg. Pin_polarity [0] = APP_PWM_POLARITY_ACTIVE_LOW; Pwm1_cfg. Pin_polarity [1] = APP_PWM_POLARITY_ACTIVE_HIGH; The polarity, in contrast, only 50% duty cycle is also good, if only 20% duty cycle appeared two road waveform is not the same, now want to two road waveform, and the 20% duty cycle is two way as the waveform. image description
