I succeeded to port s110 & sdk9 to s140 & sdk14 which was a problem before.
What we need to do now is to compare the performance of BLE devices with s110 & sdk9 (nrf51822) and bluetooth 5 devices with s140 & sdk14 (nrf52840).
In order to test bluetooth5, we modified a part by referring to "ATT_MTU Throughput Example"
Here are some of the modified sources:
--main.c
#define bBluetooth5
#ifdef bBluetooth5
#define L2CAP_HDR_LEN 4 //!< Length of a L2CAP header, in bytes.
static ble_gap_phys_t phys =
.tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
.rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED
#define CONN_INTERVAL_DEFAULT (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS)) /**< Default connection interval used at connection establishment by central side. */
void data_len_ext_set(bool status)
uint8_t data_length = status ? (247 + L2CAP_HDR_LEN) : (23 + L2CAP_HDR_LEN);
(void) nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, data_length);
static void conn_evt_len_ext_set(bool status)
ret_code_t err_code;
ble_opt_t opt;
memset(&opt, 0x00, sizeof(opt));
opt.common_opt.conn_evt_ext.enable = status ? 1 : 0;
err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
void preferred_phy_set(ble_gap_phys_t * p_phy)
#if defined(S140)
ble_opt_t opts;
memset(&opts, 0x00, sizeof(ble_opt_t));
memcpy(&opts.gap_opt.preferred_phys, p_phy, sizeof(ble_gap_phys_t));
ret_code_t err_code = sd_ble_opt_set(BLE_GAP_OPT_PREFERRED_PHYS_SET, &opts);
bool erase_bonds;
uint32_t cnt;
// Initialize.
uart_init();
log_init();
timers_init();
ble_stack_init();
gatt_init();
#ifdef bBluetooth5
data_len_ext_set(true);
conn_evt_len_ext_set(true);
preferred_phy_set(&phys);
I modified it as above.
To sum up what I want to do,
- I will find a device that supports bluetooth5. For example, the Galaxy S8.
- After finding the device, I would like to compare the performance with the existing device and the device with bluetooth5.
How do you approach performance comparisons?
Do you configure the amount of packets and check the time it takes to send them? Or is the device more responsive? How do I compare these things?
