I know that latest nRF5 SDK and nRF mesh SDK support SES, it's really a good news for developer. I'm just curious that, can I use SES to flash SoftDevice on macOS? If so, how can I load SoftDevice hex to flash? Thanks.
Hi kren,
SES should flash the SoftDevice automatically when follwing the steps in the documentation.
Best,
Thomas
Specifically, its added as an Additional Load File in the Common Configuration, see Project -> Edit Options -> Loader -> Additional Load File[0]. Note: make sure you have selected Common in the Drop-down menu.
Yes, you're correct. I can download both files, SoftDevice and Application firmware, on Windows 10. But I found that Additional Load File can be downloaded into board on Windows, but can't downloaded on macOS, I think the reason is that the file path on macOS is incorrect, please double check.
Can you try to change the path to the Additional Load file to point to the s132_nrf52_5.0.0_softdevice.hex
in components\softdevice\s132\hex
Yes, I've tested it, it works. Hope can add the $PROJ_DIR$ in next release.
