Hi, I am working with the Mesh SDK 0.10.1. Everything compiles and runs fine. However I wasn't getting any RTT logs. I found that if I put a while loop before the first call to ERROR_CHECK() the logging works fine. This is really weird!, and leads me to believe that it is getting optimized out or something? Any help greatly appreciated!
I am using OS X, gcc-arm-none-eabi-4_8-2014q1, and the CMake scripts include with the project.
Here is the function that first calls ERROR_CHECK() in "examples/nrf_mesh_sdk.c", see the while(1) loop about 2/3 the way down.
void mesh_core_setup(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing softdevice\n");
#if SD_BLE_API_VERSION >= 5
nrf_clock_lf_cfg_t lfc_cfg = {NRF_CLOCK_LF_SRC_XTAL, 0, 0, NRF_CLOCK_LF_ACCURACY_20_PPM};
#elif SD_BLE_API_VERSION >= 2
nrf_clock_lf_cfg_t lfc_cfg = {NRF_CLOCK_LF_SRC_XTAL, 0, 0, NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM};
#elif defined(S110)
nrf_clock_lfclksrc_t lfc_cfg = NRF_CLOCK_LFCLKSRC_XTAL_20_PPM;
mesh_softdevice_setup(lfc_cfg);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing mesh stack\n");
nrf_mesh_init_params_t mesh_init_params = {
.lfclksrc = lfc_cfg,
.assertion_handler = mesh_assert_handler,
//with this added RTT works fine, if compiles without this loop RTT doesn't work???
while (1) {
ERROR_CHECK(nrf_mesh_init(&mesh_init_params));
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Enabling mesh stack\n");
ERROR_CHECK(nrf_mesh_enable());
