Hi all , when I run and debug my code , I frequently encounter error :
I think it's related RAM configuration on KeilC . Please show me what is error ? And how to solve it . Thank very much !!!
debug my code
Once the softdevice (SD) is enabled, you cannot use breakpoints (or watchpoints) any longer, since these will halt the CPU core. This triggers internal timeouts in the SD - the error condition ends up in the app_error_fault_handler()
function. The id
and pc
arguments may hold some information.
You may want to check the call stack - with a wrong RAM configuration this might get called early and not always from within the SD.
You may want to check the "monitor mode" debugging that is described in this forum :)
Take a look at this post on how to debug: devzone.nordicsemi.com/.../
Thank for information , I run correct but I debug it wrong and I dont know why . now I understand .
