I am writing a combined beacon and mesh node using the mesh SDK v0.10.
When dsm_local_unicast_addresses_set()
is called in mesh_evt_handler()
, which can be found in nrf_mesh_node_config.c
a NRF_ERROR_FORBIDDEN
error is returned which results in an assert.
What can course this behavior?
This is how i initializes the mesh node:
void beacon_node_init(void)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
static nrf_mesh_node_config_params_t config_params =
.company_id = COMPANY_ID,
.prov_caps.num_elements = ACCESS_ELEMENT_COUNT,
.prov_caps.algorithms = NRF_MESH_PROV_ALGORITHM_FIPS_P256EC,
.prov_caps.oob_static_types = NRF_MESH_PROV_OOB_STATIC_TYPE_SUPPORTED,
.p_static_data = static_auth_data,
.setup_callback = configuration_setup_cb,
.complete_callback = configuration_complete_cb,
.attention_cb = NULL,
.lf_clk_cfg.source = NRF_CLOCK_LF_SRC_XTAL,
.lf_clk_cfg.xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
uint32_t err = nrf_mesh_node_config(&config_params);
ERROR_CHECK(err);
