Ble Mesh light_switch server - help debug Keil v5 project
Hi
Mesh SDK 0.10.0
I have created a keil v5 project to build the light_switch server app and it builds and links successfully. I can run it up to the following line in main()
ERROR_CHECK(nrf_mesh_node_config(&config_params));
However if I put a breakpoint at the next line ( the while loop ), I never reach there.
When I stop the application it is looping in the function sleep_forever()
I am going to continue to locate the problem, but if you are interested, you can download the project from the following dropbox location (strip out all the whitespaces )
https: // www . dropbox . com / s / ue0oiavvyripoo5/server.keilv5.zip?dl=0
Unzip it so that the file "light_switch_server_nrf52832_xxAA_s132_5_0_0.uvprojx" will be in your folder "examples\light_switch\server.keilv5"
Look forward to your feedback and thank you in advance
  • Found my error!
    I had not added the file 'prov_bearer_adv.c' and the linker did not complain because weak functions are provided in 'nrf_mesh_weak.c'
    So if you take the keil project and just add that file, on running you will see that it starts sending out unprovisioned becaons.
    I managed to add it to my mesh using the client app, however, one difference in behaviour is that I do not see it sending out Secure Network beacons which the node built with Segger does.
    That is another day, but at least there something you can play with in Keil
