I am using the PPK with SW v1.1.0 on a windows virtual machine on my mac. I'm testing custom hardware using the PPK regulator to supply power to my hardware.
There seem to be a few issues I'm running into:
The latency from power consumption events to graph changing seems very high. In particular if I turn my device on it might take 30 seconds to a minute before the graph updates to reasonable values. Same if I turn the device off.
After some amount of time (few minutes?) I see "range not detected" printed over and over in the console. Additionally the trigger window values appear to be completely unrealistic (more than 100 mA -- I expect max draw to be ~20 mA).
If I set the trigger to -- say 5000 uA -- and hit single it might take ~30 seconds to get the trigger even though the average window shows several spikes well above the trigger threshold.
Is the PC side buffer really large such that the latency is expected?
Is running on a VM not recommended?
I saw this question: devzone.nordicsemi.com/.../
It seems perhaps relevant, but I'm using default slider values.
