help! Thanks
SDK: nRF5_SDK_11.0.0
Softdevice: s132_nrf52_2.0.0_softdevice
chip:nRF52832
we found that the pstorage's callback will not be triggered when the Bluetooth device connect to the host.
First, I call the flash_init () to initialize flash in main, and then call flash_test () for data storage and read, found everything is normal, it can trigger the callback function; but if the Bluetooth device is connected to the host,then call the flash_test () when received some data will not trigger callback function, data storage failed.
Figure 1 1.png is the RTT output that I call flash_test () in the main function.
Figure 2 2.pngis the result of the RTT output from flash_test () after I received the data at com service
code:
void flash_callback(pstorage_handle_t * handle,uint8_t op_code,uint32_t result,uint8_t * p_data, uint32_t data_len)
switch(op_code)
case PSTORAGE_STORE_OP_CODE:
if (result == NRF_SUCCESS)
pstorage_wait_flag = 0;
SEGGER_RTT_printf(0,"PSTORAGE_STORE_OP_CODE\r\n");
// Update operation failed.
case PSTORAGE_LOAD_OP_CODE:
SEGGER_RTT_printf(0,"PSTORAGE_LOAD_OP_CODE\r\n");
case PSTORAGE_CLEAR_OP_CODE:
SEGGER_RTT_printf(0,"PSTORAGE_CLEAR_OP_CODE\r\n");
case PSTORAGE_UPDATE_OP_CODE:
SEGGER_RTT_printf(0,"PSTORAGE_UPDATE_OP_CODE \r\n");
void flash_init(void)
uint32_t err_code;
pstorage_module_param_t module_param;
err_code = pstorage_init();
module_param.block_count = 3;
module_param.block_size = 16;
module_param.cb = flash_callback;// //²Ù×÷»Øµ÷
err_code =pstorage_register(&module_param, &BLOCK_FLASH);//×¢²áÉêÇë
SEGGER_RTT_printf(0,"[DM]: Storage handle 0x%08X.\r\n", BLOCK_FLASH.block_id);
void flash_test(void)
uint32_t err_code;
pstorage_handle_t Flash_ID;
uint8_t User[4] = {0}; //È«¾ÖÊý×éÓÃÀ´´æ·ÅÊÖ»ú·¢¹ýÀ´µÄÊý¾Ý£¬
uint8_t buff[4] = {0x12,0x34,0x56,0x78};
SEGGER_RTT_printf(0,"\n>>[FLASH]: flash_test \r\n");
pstorage_block_identifier_get(&BLOCK_FLASH, 2, &Flash_ID);
SEGGER_RTT_printf(0,"[DM]: Storage handle 0x%08X.\r\n", Flash_ID.block_id);
pstorage_clear(&Flash_ID, 16);
pstorage_wait_flag = 1; //Set the wait flag. Cleared in the example_cb_handler
SEGGER_RTT_printf(0,"pstorage wait for clear to complete ... \r\n");
while(pstorage_wait_flag) { power_manage(); } //Sleep until clear operation is finished.
pstorage_update(&Flash_ID, buff, 4, 0);
SEGGER_RTT_printf(0,"pstorage wait for update to complete ... \r\n");
while(pstorage_wait_flag) { power_manage(); } //Sleep until update operation is finished.
pstorage_load(User, &Flash_ID, 4, 0); //¶ÁÈ¡¿éÄÚÊý¾Ý
SEGGER_RTT_printf(0,"pstorage wait for load to complete ... \r\n");
while(pstorage_wait_flag) { power_manage(); } //Sleep until load operation is finished.
SEGGER_RTT_printf(0,"%x\r\n",User[0]);
SEGGER_RTT_printf(0,"%x\r\n",User[1]);
SEGGER_RTT_printf(0,"%x\r\n",User[2]);
SEGGER_RTT_printf(0,"%x\r\n",User[3]);
SEGGER_RTT_printf(0,"<<[FLASH]: flash_test \r\n\n");
enter code here
