I'm trying to implement a BLE Central device on an STM32 using Serialization to connect with an nRF52-DK board; I've previously gotten a BLE Peripheral working on the same setup (in this case I'm not trying to use Central and Peripheral in the same firmware).
I've used the HRS_C example as reference and I can't seem to get a response from scanning / the ble_evt ADV_REPORT. I don't appear to be getting any returned errors (I've double and triple checked that all returned error codes are checked). Once the ble_stack is initialized, bonded pairs are deleted, and scanning is started, I receive no scanned data from the nRF52832.
Edit: Further testing shows that if I try to use the ble_manager_whitelist_disable function, the nRF52832 will stop responding in certain circumstances. I set the timeout to 2 seconds and print when the timeout occurs and the scanning is restarted; I can watch the scanning stop and start and continue to do so until I start advertising on any nearby bluetooth peripheral; at this point the nRF52832 stops responding...
Attached is my code and the decoded SPI packets from Saleae:
INCLUDES
//#define USE_EXAMPLE_SERVICES
//Standard Includes
#include <stdbool.h>
#include <stdint.h>
#include <stddef.h>
//This Header
#include "ble_manager.h"
//Application Module Includes
#include "dbg.h"
#include "datetime.h"
//Application Device Includes
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "ble_hrs_c.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "ble_conn_state.h"
#include "app_scheduler.h"
//ESA MCO CAN Includes
//Device Manufacturer Library Includes
LOCAL DEFINITIONS
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 1 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_SOC_OBSERVER_PRIO 1 /**< Applications' SoC observer priority. You shoulnd't need to modify this value. */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x00A0 /**< Determines scan window in units of 0.625 millisecond. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size in octets. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define TARGET_UUID BLE_UUID_HEART_RATE_SERVICE /**< Target device name that application is looking for. */
/**@breif Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
do \
(*(DST)) = (SRC)[1]; \
(*(DST)) <<= 8; \
(*(DST)) |= (SRC)[0]; \
} while (0)
/**@brief Variable length data encapsulation in terms of length and pointer to data */
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
#define NRF_LOG_DEBUG(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER, "NRF_DBG: " format"\n", ##__VA_ARGS__);
#define NRF_LOG_INFO(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER, "NRF_LOG: " format "\n", ##__VA_ARGS__);
#define NRF_LOG_ERROR(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER, "NRF_ERR: " format "\n", ##__VA_ARGS__);
BLE_HRS_C_DEF(m_hrs_c); /**< Structure used to identify the heart rate client module. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_whitelist_disabled; /**< True if whitelist has been temporarily disabled. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
static bool m_retry_db_disc; /**< Flag to keep track of whether the DB discovery should be retried. */
static uint16_t m_pending_db_disc_conn = BLE_CONN_HANDLE_INVALID; /**< Connection handle for which the DB discovery is retried. */
static ble_gap_scan_params_t m_scan_param; /**< Scan parameters requested for scanning and connection. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, /**< Minimum connection. */
(uint16_t)MAX_CONNECTION_INTERVAL, /**< Maximum connection. */
(uint16_t)SLAVE_LATENCY, /**< Slave latency. */
(uint16_t)SUPERVISION_TIMEOUT /**< Supervision time-out. */
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
* if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = ""; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false; /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
/* Possible values for addr_type:
BLE_GAP_ADDR_TYPE_PUBLIC,
BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
.addr = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}
EXTERNAL REFERENCES
PUBLIC DEFINITIONS
LOCAL FUNCTION PROTOTYPES
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt);
* @brief Parses advertisement data, providing length and location of the field in case
* matching data is found.
* @param[in] Type of data to be looked for in advertisement data.
* @param[in] Advertisement report length and pointer to report.
* @param[out] If data type requested is found in the data report, type data length and
* pointer to data will be populated here.
* @retval NRF_SUCCESS if the data type is found in the report.
* @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void);
/**@brief Retrieve a list of peer manager peer IDs.
* @param[inout] p_peers The buffer where to store the list of peer IDs.
* @param[inout] p_size In: The size of the @p p_peers buffer.
* Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size);
static void whitelist_load(void);
static void scan_start(void);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void);
/**@brief Function for starting application timers.
static void application_timers_start(void);
static void sleep_mode_enter(void);
* @param[in] ble_adv_evt Advertising event.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt);
/**@brief Function for searching a given addr in the advertisement packets.
* @details Use this function to parse received advertising data and to find a given
* addr in them.
* @param[in] p_adv_report advertising data to parse.
* @param[in] p_addr name to search.
* @return true if the given name was found, false otherwise.
static bool find_peer_addr(const ble_gap_evt_adv_report_t *p_adv_report, const ble_gap_addr_t * p_addr);
/**@brief Function for searching a UUID in the advertisement packets.
* UUID in them.
* @param[in] uuid_to_find UUIID to search.
* @return true if the given UUID was found, false otherwise.
static bool find_adv_uuid(const ble_gap_evt_adv_report_t *p_adv_report, const uint16_t uuid_to_find);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context);
static void ble_stack_init(void);
///**@brief Function for handling events from the BSP module.
// * @param[in] event Event generated by button press.
//void bsp_event_handler(bsp_event_t event);
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt);
* @brief Heart rate collector initialization.
static void hrs_c_init(void);
* @brief Database discovery collector initialization.
static void db_discovery_init(void);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void);
//static void advertising_init(void);
/**@brief Function for the Power manager.
static void power_manage(void);
PUBLIC FUNCTIONS
void ble_manager_init(void)
bool erase_bonds = true;
// Initialize.
timers_init();
ble_stack_init();
gatt_init();
peer_manager_init();
db_discovery_init();
hrs_c_init();
#if APP_SCHEDULER_ENABLED
APP_SCHED_INIT(30, 10);
// Start execution.
application_timers_start();
if (erase_bonds == true)
delete_bonds();
// Scanning is started by PM_EVT_PEERS_DELETE_SUCCEEDED
scan_start();
void ble_manager_update(void)
app_sched_execute();
/**@brief Function for disabling the use of whitelist for scanning.
void ble_manager_whitelist_disable(void)
if (!m_whitelist_disabled)
NRF_LOG_INFO("Whitelist temporarily disabled.");
m_whitelist_disabled = true;
sd_ble_gap_scan_stop();
scan_start();
LOCAL FUNCTIONS
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
// ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
DEBUG_PRINTF(DEBUG_MAIN, "%s", "DB Disc Event\n");
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
scan_start();
} break;
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// The local database has likely changed, send service changed indications.
pm_local_database_has_changed();
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
uint32_t index = 0;
uint8_t * p_data;
p_data = p_advdata->p_data;
while (index < p_advdata->data_len)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index + 1];
if (field_type == type)
p_typedata->p_data = &p_data[index + 2];
p_typedata->data_len = field_length - 1;
return NRF_SUCCESS;
index += field_length + 1;
return NRF_ERROR_NOT_FOUND;
// Initialize timer module.
err_code = app_timer_init();
pm_peer_id_t peer_id;
uint32_t peers_to_copy;
peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
*p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
*p_size = 0;
while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
p_peers[(*p_size)++] = peer_id;
peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load()
ret_code_t ret;
pm_peer_id_t peers[8];
uint32_t peer_cnt;
memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
// Load all peers from flash and whitelist them.
peer_list_get(peers, &peer_cnt);
ret = pm_whitelist_set(peers, peer_cnt);
APP_ERROR_CHECK(ret);
// Setup the device identies list.
// Some SoftDevices do not support this feature.
ret = pm_device_identities_list_set(peers, peer_cnt);
if (ret != NRF_ERROR_NOT_SUPPORTED)
/**@brief Function to start scanning.
if (nrf_fstorage_is_busy(NULL))
m_memory_access_in_progress = true;
return;
// Whitelist buffers.
ble_gap_addr_t whitelist_addrs[8];
ble_gap_irk_t whitelist_irks[8];
memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
memset(whitelist_irks, 0x00, sizeof(whitelist_irks));
uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
// Reload the whitelist and whitelist all peers.
whitelist_load();
ret_code_t ret;
// Get the whitelist previously set using pm_whitelist_set().
ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
m_scan_param.active = 1;
m_scan_param.interval = SCAN_INTERVAL;
m_scan_param.window = SCAN_WINDOW;
if (((addr_cnt == 0) && (irk_cnt == 0)) ||
(m_whitelist_disabled))
// Don't use whitelist.
m_scan_param.use_whitelist = 0;
m_scan_param.adv_dir_report = 1;
m_scan_param.timeout = 0x0000; // No timeout.
// Use whitelist.
m_scan_param.use_whitelist = 1;
m_scan_param.adv_dir_report = 0;
m_scan_param.timeout = 0x001E; // 30 seconds.
NRF_LOG_INFO("Starting scan.");
ret = sd_ble_gap_scan_start(&m_scan_param);
// ret = bsp_indication_set(BSP_INDICATE_SCANNING);
case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
p_evt->conn_handle,
p_evt->params.att_mtu_effective);
} break;
case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
p_evt->conn_handle,
p_evt->params.data_length);
} break;
if (m_retry_db_disc)
NRF_LOG_DEBUG("Retrying DB discovery.");
m_retry_db_disc = false;
// Discover peer's services.
err_code = ble_db_discovery_start(&m_db_disc, m_pending_db_disc_conn);
if (err_code == NRF_ERROR_BUSY)
NRF_LOG_DEBUG("ble_db_discovery_start() returned busy, will retry later.");
m_retry_db_disc = true;
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
/**@brief Function for searching a given name in the advertisement packets.
* name in them either as 'complete_local_name' or as 'short_local_name'.
* @param[in] name_to_find name to search.
static bool find_adv_name(ble_gap_evt_adv_report_t const * p_adv_report, char const * name_to_find)
data_t adv_data;
data_t dev_name;
// Initialize advertisement report for parsing
adv_data.p_data = (uint8_t *)p_adv_report->data;
adv_data.data_len = p_adv_report->dlen;
//search for advertising names
err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, &adv_data, &dev_name);
if (err_code == NRF_SUCCESS)
if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len) == 0)
return true;
// Look for the short local name if it was not found as complete
err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name);
if (err_code != NRF_SUCCESS)
return false;
if (memcmp(m_target_periph_name, dev_name.p_data, dev_name.data_len )== 0)
return true;
return false;
* addr in them.
if (p_addr->addr_type == p_adv_report->peer_addr.addr_type)
if (memcmp(p_addr->addr, p_adv_report->peer_addr.addr, sizeof(p_adv_report->peer_addr.addr)) == 0)
return true;
return false;
* UUID in them.
data_t adv_data;
data_t type_data;
// Initialize advertisement report for parsing.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE,
&adv_data,
&type_data);
// Look for the services in 'complete' if it was not found in 'more available'.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE,
&adv_data,
&type_data);
// If we can't parse the data, then exit.
return false;
// Verify if any UUID match the given UUID.
for (uint32_t u_index = 0; u_index < (type_data.data_len / sizeof(uint16_t)); u_index++)
uint16_t extracted_uuid;
UUID16_EXTRACT(&extracted_uuid, &type_data.p_data[u_index * sizeof(uint16_t)]);
if (extracted_uuid == uuid_to_find)
return true;
return false;
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
m_pending_db_disc_conn = p_ble_evt->evt.gap_evt.conn_handle;
NRF_LOG_INFO("ble_db_discovery_start() returned busy, will retry later.");
// err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
if (ble_conn_state_n_centrals() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
scan_start();
} break;
case BLE_GAP_EVT_ADV_REPORT:
bool do_connect = false;
if (is_connect_per_addr)
if (find_peer_addr(&p_gap_evt->params.adv_report, &m_target_periph_addr))
NRF_LOG_INFO("Address match send connect_request.");
do_connect = true;
else if (strlen(m_target_periph_name) != 0)
if (find_adv_name(&p_gap_evt->params.adv_report, m_target_periph_name))
do_connect = true;
NRF_LOG_INFO("Name match send connect_request.");
if (find_adv_uuid(&p_gap_evt->params.adv_report, TARGET_UUID))
do_connect = true;
NRF_LOG_INFO("UUID match send connect_request.");
if (do_connect)
// Stop scanning.
(void) sd_ble_gap_scan_stop();
#if (NRF_SD_BLE_API_VERSION <= 2)
m_scan_param.selective = 0;
#if (NRF_SD_BLE_API_VERSION >= 3)
// Initiate connection.
err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr,
&m_scan_param,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
m_whitelist_disabled = false;
NRF_LOG_ERROR("Connection Request Failed, reason %d.", err_code);
} break; // BLE_GAP_EVT_ADV_REPORT
NRF_LOG_INFO("Disconnected, reason 0x%x.",
p_ble_evt->evt.gap_evt.params.disconnected.reason);
// err_code = bsp_indication_set(BSP_INDICATE_IDLE);
// Reset DB discovery structure.
memset(&m_db_disc, 0 , sizeof (m_db_disc));
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_DEBUG("Scan timed out.");
scan_start();
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
#if defined(S132)
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
/**@brief SoftDevice SoC event handler.
* @param[in] evt_id SoC event.
* @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
switch (evt_id)
case NRF_EVT_FLASH_OPERATION_SUCCESS:
/* fall through */
case NRF_EVT_FLASH_OPERATION_ERROR:
if (m_memory_access_in_progress)
m_memory_access_in_progress = false;
scan_start();
// No implementation needed.
ret_code_t err_code = 0;
uint32_t ram_start = 0;
// Enable BLE stack.
NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
switch (p_hrs_c_evt->evt_type)
case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_DEBUG("Heart rate service discovered.");
err_code = ble_hrs_c_handles_assign(p_hrs_c,
p_hrs_c_evt->conn_handle,
&p_hrs_c_evt->params.peer_db);
// Initiate bonding.
err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
// Heart rate service discovered. Enable notification of Heart Rate Measurement.
err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
} break;
case BLE_HRS_C_EVT_HRM_NOTIFICATION:
NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0)
uint32_t rr_avg = 0;
for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++)
rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
} break;
ble_hrs_c_init_t hrs_c_init_obj;
hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
static void fds_evt_handler(fds_evt_t const * const p_evt)
if (p_evt->id == FDS_EVT_GC)
NRF_LOG_DEBUG("GC completed\n");
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
// // central
err_code = fds_register(fds_evt_handler);
ret_code_t err_code = sd_app_evt_wait();
