Hi
I seek your support for the following 2 app_timer (or else) issue:
(1) in there any reason as to why multiple app_timers will sometime trigger all in a row although they have very different timeouts?
My case is button detection for short, long and very long presses: when a press is detected, it fires 2 timers, then depending on when you depress, related timers are _stop-ped and the correct handler is called. It usually works well. But sometimes (usually after a reset and low battery and the softdevice being initialized but not used), if I press, I get short + long-handler + very-long-handlers being fired all in a row as if timers had a timeout of 0.
same effect with a GPIO based trigger that turns the display on to show some data until a given display timeout (app_timer based). Sometimes (same situation as previous), the display timeout handler is called immediately as if timeout is 0.
In both case, all app_timer timeouts are hardcoded (#define)
(2) considering a timeout function that sometimes needs to be extended (display timeout set to 4sec, some consequent events may need to reset (or change) the timeout): sometimes the app_timer_stop and _start sequence is not respected; being aware that those calls are actually queued and then interrupted, I scheduled the { _stop _start } ... but that does not help...
Final note: I cannot reproduce the cases on demand. I am also trying to isolate the issue (dedicated app) but without success until now...
env: { N51822 QFAAH0 1627WW + sdk_v5_2_0_39364 }
thank you
