I want to receive the More data (>20 bytes) in nrf51822 Board from the nRF ToolBox UART module.
is this possible?
What will be changed to be done in peripheral side? please suggest me....
Thank You
is this possible?
Thank You
Surely it is possible, simply ut your large sting to 20-byte blocks. Alternatively (if you are not able to deal with unstructured flow) you may invent some fragmentation/reassembly layer with simple header in each block (it will lower your bandwidth but allow to do some advanced things if needed).
@Milav: You can split your data in to 20byte trunks as suggested by endnode. Or if your central device support long MTU, you can actually extend the MTU to meet your requirement. Then you can do notification up to the new MTU bytes on each notification.
