I am working in sdk14.1 nrf52832 ble_app_hids_keyboard_pca10040_s132.
I have successfully implemented a keyboard + Consumer control command in the HID service.
It works great on IOS and Android but no work on PC (Win10).
PC and BLE Disconnected after connecting.
here is some of the important code :
static void hids_init(void)
ret_code_t err_code;
ble_hids_init_t hids_init_obj;
ble_hids_inp_rep_init_t input_report_array[1];
ble_hids_inp_rep_init_t * p_input_report;
ble_hids_outp_rep_init_t output_report_array[1];
ble_hids_outp_rep_init_t * p_output_report;
uint8_t hid_info_flags;
memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
static uint8_t report_map_data[] =
// Report ID 1
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x06, // Usage (Keyboard)
0xA1, 0x01, // Collection (Application)
0x85, 0x01, // Report Id (1)
0x05, 0x07, // Usage Page (Key Codes)
0x19, 0xe0, // Usage (224)
0x29, 0xe7, // Usage Maximum (231)
0x15, 0x00, // Logical MinMinimumimum (0)
0x25, 0x01, // Logical Maximum (1)
0x75, 0x01, // Report Size (1)
0x95, 0x08, // Report Count (8)
0x81, 0x02, // Input (Data, Variable, Absolute)
0x95, 0x01, // Report Count (1)
0x75, 0x08, // Report Size (8)
0x81, 0x01, // Input (Constant) reserved byte(1)
0x95, 0x05, // Report Count (5)
0x05, 0x08, // Usage Page (Page# for LEDs)
0x19, 0x01, // Usage Minimum (1)
0x29, 0x05, // Usage Maximum (5)
0x91, 0x02, // Output (Data, Variable, Absolute), Led report
0x75, 0x03, // Report Size (3)
0x91, 0x01, // Output (Data, Variable, Absolute), Led report padding
0x95, 0x06, // Report Count (6)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x65, // Logical Maximum (101)
0x05, 0x07, // Usage Page (Key codes)
0x19, 0x00, // Usage Minimum (0)
0x29, 0x65, // Usage Maximum (101)
0x81, 0x00, // Input (Data, Array) Key array(6 bytes)
0x09, 0x05, // Usage (Vendor Defined)
0x26, 0xFF, 0x00, // Logical Maximum (255)
0x75, 0x08, // Report Count (2)
0x95, 0x02, // Report Size (8 bit)
0xB1, 0x02, // Feature (Data, Variable, Absolute)
0xC0,
// Report ID 2: Advanced buttons
0x05, 0x0C, // Usage Page (Consumer)
0x09, 0x01, // Usage (Consumer Control)
0x85, 0x02, // Report Id (2)
0x15, 0x00, // Logical minimum (0)
0x25, 0x01, // Logical maximum (1)
0x09, 0xB8, // B8=>eject
0x81, 0x02, // Input (Data,Value,Relative,Bit Field)
0x0A, 0xCC,//0x83, 0x01, // Usage (AL Consumer Control Configuration)
0x09, 0xB5, // Usage (Scan Next Track)
0x09, 0xB6, // Usage (Scan Previous Track)
0x09, 0xEA, // Usage (Volume Down)
0x09, 0xE9, // Usage (Volume Up)
0x0A, 0x25, 0x02, // Usage (AC Forward)
0x0A, 0x24, 0x02, // Usage (AC Back)
0xC0 // End Collection (Application)*/
// Initialize HID Service
p_input_report = &input_report_array[INPUT_REPORT_KEYS_INDEX];//0
p_input_report->max_len = INPUT_REPORT_KEYS_MAX_LEN; //9
p_input_report->rep_ref.report_id = INPUT_REP_REF_ID;//0
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;//1
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
p_output_report = &output_report_array[OUTPUT_REPORT_INDEX];//0
p_output_report->max_len = OUTPUT_REPORT_MAX_LEN;//1
p_output_report->rep_ref.report_id = OUTPUT_REP_REF_ID;//0
p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;//2
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler = on_hids_evt;
hids_init_obj.error_handler = service_error_handler;
hids_init_obj.is_kb = true;
hids_init_obj.is_mouse = false;
hids_init_obj.inp_rep_count = 1;
hids_init_obj.p_inp_rep_array = input_report_array;
hids_init_obj.outp_rep_count = 1;
hids_init_obj.p_outp_rep_array = output_report_array;
hids_init_obj.feature_rep_count = 0;
hids_init_obj.p_feature_rep_array = NULL;
hids_init_obj.rep_map.data_len = sizeof(report_map_data);
hids_init_obj.rep_map.p_data = report_map_data;
hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags = hid_info_flags;
hids_init_obj.included_services_count = 0;
hids_init_obj.p_included_services_array = NULL;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
&hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
err_code = ble_hids_init(&m_hids, &hids_init_obj);
