Debugging Hardfault - Registers Not Consistent
I'm trying to debug a randomly occuring Hardfault. In trying to trace down the source I read the CPU registers use the Nordic hardfault_implementation.c which grabs the register values. These values are different then the CPU register values I read at the hardfault via Segger J-Link. Also they different from the follow recommended code from freeRTOS:
__asm volatile
    " tst lr, #4                                                \n"
    " ite eq                                                    \n"
    " mrseq r0, msp                                             \n"
    " mrsne r0, psp                                             \n"
    " ldr r1, [r0, #24]                                         \n"
    " ldr r2, handler2_address_const                            \n"
    " bx r2                                                     \n"
    " handler2_address_const: .word prvGetRegistersFromStack    \n"
So I'm at a loss which set of values to go with first of all.
  1. Secondly, the PC sometimes halts in RAM i.e. 0x20005828, other times it halts in Flash i.e. 0x23CAC. I believe the memory in the Eclipse Disassembly Window is only RAM memory. How do you go about debugging/finding the source of hardfault bugs? I've tried cross referencing the PC value to the memory locations mapped in the .MAP file as well. I know there are a few other posts on hardfault debugging, but most relate to using Keil not Eclipse for tracing.
  2. Randomly the PC value is 0xA5A5A5A5, which i know indicates a Stack Corruption. I am using SAADC and HVX calls on separate threads and very quickly. Could these be grinding down the Stack? I know SAADC blocks during sampling.
I appreciate the help guys.
