I'm using the LSM6DS3 IMU using SPI. I am able to read the WHO_AM_I register and retrieve the correct data with this code based on the spi example from the SDKv14.2.0 :
static uint8_t m_tx_buf[2]; /**< TX buffer. */
static uint8_t m_rx_buf[2]; /**< RX buffer */
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_HEXDUMP_INFO(m_rx_buf, rx_length);
m_tx_buf[0] = (SPI_READ | LSM6DS3_WHO_AM_I );
m_tx_buf[1] = 0;
while (1)
memset(m_rx_buf, 0, rx_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 1, m_rx_buf, rx_length));
while (!spi_xfer_done)
__WFE();
I get the following output from the NRF_LOG_HEXDUMP_INFO : 00 69 has expected from the datasheet.
Now I want to retrieve value from the accelerometer but according to the doc, the result is splitted between two registers ! For example for Z-axis : OUTZ_L_XL (address : 0x2C) for LSbyte OUTZ_H_XL (address : 0x2D) for MSbyte
How do I read the two registers one after the other without risking to loose data ?
Because if I do :
m_tx_buf[0] = (SPI_READ | LSM6DS3_OUTZ_L_XL );
m_tx_buf[0] = (SPI_READ | LSM6DS3_OUTZ_H_XL );
How can I be sure that the LSB and the MSB that I read are supposed to be together and that the value didn't change between the two transfer calls ?
I hope it's not too blurred.
As an example, here is how they do it for Arduino but I can find a way to reproduce this with the SDK.
Thanks for your help
