in my circuit, it takes 17ms for VCC_NRF to go up from 0 to 1.7V and reach 3.0V, but nRESET PIN does NOT to go up to VCC_NRF. what is the potential cause of this problem?
here is the waveform for VCC_NRF and nRESET
Does the nRESET signal never go high?
Are you measuring on pin 21 ?
Is anything connected to pin 21?
What SDK version are you using? What example in the SDK are you testing this with?
ogura did you ever determine the cause of this? Have a similar power up issue on a board with an LDO that takes almost 1ms to get to minimum 1.76V
Turned out to be a DC/DC loading issue. 2.2uF was stuffed instead of a 100nF for the DEC caps. Seems like some unknown inductors were also stuffed.
