Hello, I have designed a PCB (25mmx55mm) and placed the nRF24l01 module (available as a standard add on module). But I am unable to get the data out of the board. I have tried the same design with the board size a little larger (50mmx50mm) and the nRF module works fine with data being transmitted to a nearby device. Is there a size restriction on the PCB for using these modules? If anyone has a solution or could point out what I may be doing incorrectly - will be much appreciated. Thanks!
