how to use multiple advertiser_packet_send() on nrfmesh
I run follow,
advertiser_t m_adv;
adv_packet_t m_packet[2];
m_packet[0] = advertiser_packet_alloc(&m_adv, 10);
advertiser_packet_send(&m_adv, &m_packet[0]);
m_packet[1] = advertiser_packet_alloc(&m_adv, 20);
advertiser_packet_send(&m_adv, &m_packet[1]);
Is work successful?
And,
How work scheduling m_packet[0] and m_packet[1]?
  • Could you elaborate more on what exactly you want to do ? What is the content of data you want to advertise ? Are you following Bluetooth Mesh or you want to create your own mesh protocol ?
    As described in the description of advertiser_packet_send, I don't see any problem here.
     * Sends a given packet using the given advertiser instance, this can be called multiple times
     * without having to wait for a tx_complete (@see advertiser_tx_complete_cb_t) on the previous
     * packets.
     * @note       Once the packet is sent successfully, the @c tx_complete_callback in the @c p_adv
     *             will be called with @c p_packet and @c p_adv as parameters to the callback.
     * @param[in,out] p_adv     An already initialized advertiser instance.
     * @param[in,out] p_packet  A valid packet that was allocated using @ref advertiser_packet_alloc, and
     *                          the the same advertiser instance as given to this function.
  • When some advertiser_packet_send() is called, I want to know how to behave.
    I try it. advertise interval is 100ms.
    first call is set to '5 count'. second call is set to '10 count'.
    first packet is send 5-advertises per 100ms(total 500ms)
    next,
    second packet is send 10-advertises per 100ms(total 1000ms)
    It'is correct?
  • You need to check for tx complete call back to make sure that the advertising packets are sent. But could you explain what you are planing to do ?
  • Thank you.
    I plan that merge NRFMESH and own proprietary MESH library.
    Own MESH library send advertise by 'varius-interval'.
    So that, I want to understand NRFMESH send scheduling.
