Error using nRF Master Control Panel - Error (0x8)
Hello, I'm using the nRF6310 board and tried the HID Keyboard Application (S110, ble_app_hids_keyboard) example.
The nRF51 SDK version is 6.1. I use IAR for ARM 7.1.
I downloaded the example code and tried to connect the board with the Master Control Panel app. I use LG Nexus 5 D821.
While connecting, a error message had appeared.
nRF Master Control Panel, 2015-01-07
 Nordic_Keyboard (F3:7C:22:93:EA:42)
 V 13:22:19.023 Connecting to F3:7C:22:93:EA:42...
 D 13:22:19.033 gatt = device.connectGatt(autoConnect = true)
 D 13:22:19.564 [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
 D 13:22:19.580 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
 I 13:22:19.666 Connected to F3:7C:22:93:EA:42
 V 13:22:20.303 Discovering Services...
 D 13:22:20.316 gatt.discoverServices()
 D 13:22:21.870 [Callback] Services discovered with status: 0
 I 13:22:21.897 Services Discovered
 V 13:22:21.949 Generic Access (0x1800)
 - Device Name [R W] (0x2A00)
 - Appearance [R] (0x2A01)
 - Peripheral Preferred Connection Parameters [R] (0x2A04)
 Generic Attribute (0x1801)
 Device Information (0x180A)
 - Manufacturer Name String [R] (0x2A29)
 - PnP ID [R] (0x2A50)
 Battery Service (0x180F)
 - Battery Level [N R] (0x2A19)
    Client Characteristic Configuration (0x2902)
 Human Interface Device (0x1812)
 - Protocol Mode [R WNR] (0x2A4E)
 - Report [N R W] (0x2A4D)
    Report Reference (0x2908)
 - Report [R W WNR] (0x2A4D)
 - Report Map [R] (0x2A4B)
 - Boot Keyboard Input Report [N R] (0x2A22)
 - Boot Keyboard Output Report [R W WNR] (0x2A32)
 - HID Information [R] (0x2A4A)
 - HID Control Point [WNR] (0x2A4C)
 D 13:23:28.517 [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED)
 D 13:23:28.545 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
 E 13:23:28.571 Error (0x8): GATT INSUF AUTHORIZATION
 D 13:23:28.595 gatt.refresh()
After refreshing, it does not try to connect.
I did not change the example code. Why do I recieve the error?
Thank you for helping me!
custom.h
hid main.txt
