button_event_handler not working properly?
  • Custom Board which has NordicSemi nRF51822-QFAA (QFAAH0, Rev. 3) MCU,
The board follows the internal LDO setup.
(Ref. nRF51822_PS v3.1 Section 11.3.1)
I added LED and button initializing codes.
  • IAR for ARM 7.1
  • Testing with iPhone 5S, 6 and iPad air (iOS 8.3)
    / Nexus 5 and Galaxy Note 3 (Android 4.4.2).
  • Using J-Link Debugger
The scheduler, timers, and BLE settings are all fine.
My problem is that the button init doesn't work properly.
buttons
I modified the code in order to divide into files. I don't use the bsp functions.
before
It seems okay at here. However, after calling any functions,
(in this example, after calling timers_start) the mp_buttons become corrupted.
(calling leds_ok didn't changed mp_buttons.)
after
So, when I press the button,
it does call detection_delay_timeout_handler in app_button.c
However, it doesn't jumps to the button_event_handler.
call
Other parts works well. (The timer interrupts, hrs handling, beacon advertising, and etc.)
What could be the reason for the mp_buttons to become corrupted?
What settings did I missed?
The compiler optimization level is "low".
Also, I use the scheduler.
I also tried the bsp_init. Although the event handler function pointer was set to null
err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                    APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                    NULL);
in this case, the values of mp_buttons didn't change when the program counter changes.
Plus, when a button is pressed, the program jumps to bsp_button_event_handler.
static void bsp_button_event_handler(uint8_t pin_no, uint8_t button_action)
(Although, it doesn't call any functions since the parameter was NULL)
When the program counter comes here, the values of mp_buttons were valid as I configured.
-Regards
  • Holy cow, I made a terrible mistake. Sorry T.T.
    The problem occurred due to the pointer reference of mp_buttons.
    Stack setting
    This was the default setting of the Stack size.
    Sit 1
    == Situation : if buttons[] is local variable ==
    (I divided source codes into several .c files.
    The main function and buttons_init function is located at different .c files.)
    After the buttons_init function was called, mp_buttons were set.
    mp_button
    As you see, mp_button is referencing memory 0x20003168.
    However, as I wrote at the question, after calling any functions, this value changes.
    Overwrite
    At the CStack, the location of 0x20003168 is now changed
    because I declared the buttons[] as a local variable and now it has different values. (D'oh!!)
    CStack
    app_buttons
    I didn't thought that mp_buttons will use referencing.
    I just guessed (without looking the code...)
    app_button_init will call memcpy or etc to copy the values.
    So the problem is solved by declaring the buttons[] as a static variable or global variable.
    Sorry for this mess... I should have thought more.
    -Regards
