The ARM Linker has stopped working
Hi
I am trying the nRF51822 Evaluation Kit for the first time. I have followed the instructions in the User Guide v1.1. The blinky_example works fine, indicating that the tool-chain should be in place. But, when I am trying to build the heart-rate monitor example, the Linker crashes and I get the Build Output window I get a message:
Build target 'nrf51822_xxaa_s110 (256K)' compiling ble_conn_params.c... compiling ble_stack_handler.c... linking... ._build\ble_app_hrs.axf: error: L6002U: Could not open file ._build\ble_conn_params.o: No such file or directory "._build\ble_app_hrs.axf" - 1 Errors, 0 Warning(s). Target not created
I have not yet installed the PCA-10000 dongle. Below I have pasted in the information from the IDE (I am using Windows8-x64). Any suggestion to how I can proceed?
IDE-Version: µVision V4.72.10.0 Copyright (C) 2013 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information: Arne Laugstol Sharp Software AS LIC=----
Tool Version Numbers: Toolchain: MDK-Lite Version: 4.72.1.0 Toolchain Path: C:\Keil\ARM\ARMCC\bin
C Compiler: Armcc.Exe V5.03.0.76 [Evaluation] Assembler: Armasm.Exe V5.03.0.76 [Evaluation] Linker/Locator: ArmLink.Exe V5.03.0.76 [Evaluation] Librarian: ArmAr.Exe V5.03.0.76 [Evaluation] Hex Converter: FromElf.Exe V5.03.0.76 [Evaluation] CPU DLL: SARMCM3.DLL V4.72.1.0 Dialog DLL: DARMCM1.DLL V1.11.00.0 Target DLL: Segger\JL2CM3.dll Dialog DLL: TARMCM1.DLL V1.08.00.0
    Thats strange. It almost sounds like a write permission error?
    Is the "_build" directory created? Does it hold any .o and .axf files?
    What happens if you go to the start meny, right click on "Keil uVision 4" and choose "Run as administrator" and then open the project from within uVision?
    Best regards Håkon
  • Hi
    I tried to run as an Administrator (but, I don't know if the Linker will run as an administrator). However, I got the same result.
    I also tried to make all files read/write-able from the Keil-root. But, the same result.
    Directory of C:\Keil\ARM\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_hr arm_build
    24.07.2013 15:50 . 24.07.2013 15:50 .. 24.07.2013 15:50 253 516 app_button.crf 24.07.2013 15:50 1 576 app_button.d 24.07.2013 15:50 248 416 app_gpiote.crf 24.07.2013 15:50 1 299 app_gpiote.d 24.07.2013 15:50 231 880 app_gpiote.o 24.07.2013 15:50 267 593 app_timer.crf 24.07.2013 15:50 1 569 app_timer.d 24.07.2013 15:49 87 arm_startup_nrf51.d 24.07.2013 15:49 31 418 arm_startup_nrf51.lst 24.07.2013 15:49 4 716 arm_startup_nrf51.o 24.07.2013 15:49 312 048 battery.crf 24.07.2013 15:49 2 537 battery.d 24.07.2013 15:49 284 232 battery.o 24.07.2013 15:50 107 143 ble_advdata.crf 24.07.2013 15:50 1 816 ble_advdata.d 24.07.2013 15:49 785 ble_app_hrs.lnp 24.07.2013 15:50 1 211 ble_app_hrs.plg 22.07.2013 12:51 479 ble_app_hrs.sct 22.07.2013 12:12 479 ble_app_hrs_sct.Bak 24.07.2013 15:49 104 319 ble_bas.crf 24.07.2013 15:49 1 730 ble_bas.d 24.07.2013 15:50 308 029 ble_bondmngr.crf 24.07.2013 15:50 2 340 ble_bondmngr.d 24.07.2013 15:50 290 644 ble_bondmngr.o 24.07.2013 15:49 114 564 ble_conn_params.crf 24.07.2013 15:49 2 229 ble_conn_params.d 24.07.2013 15:50 48 727 ble_debug_assert_handler.crf 24.07.2013 15:50 1 043 ble_debug_assert_handler.d 24.07.2013 15:49 100 150 ble_dis.crf 24.07.2013 15:49 1 657 ble_dis.d 24.07.2013 15:50 232 059 ble_error_log.crf 24.07.2013 15:50 1 296 ble_error_log.d 24.07.2013 15:50 215 936 ble_error_log.o 24.07.2013 15:50 256 543 ble_flash.crf 24.07.2013 15:50 1 487 ble_flash.d 24.07.2013 15:50 237 432 ble_flash.o 24.07.2013 15:49 107 442 ble_hrs.crf 24.07.2013 15:49 1 730 ble_hrs.d 24.07.2013 15:49 101 168 ble_hrs.o 24.07.2013 15:50 235 123 ble_radio_notification.crf 24.07.2013 15:50 1 271 ble_radio_notification.d 24.07.2013 15:50 209 540 ble_radio_notification.o 24.07.2013 15:50 77 579 ble_srv_common.crf 24.07.2013 15:50 1 382 ble_srv_common.d 24.07.2013 15:50 286 576 ble_stack_handler.crf 24.07.2013 15:50 2 512 ble_stack_handler.d 24.07.2013 15:49 254 431 led.crf 24.07.2013 15:49 1 401 led.d 24.07.2013 15:49 235 508 led.o 24.07.2013 15:49 340 747 main.crf 24.07.2013 15:49 3 250 main.d 24.07.2013 15:49 231 616 system_nrf51.crf 24.07.2013 15:49 783 system_nrf51.d 24.07.2013 15:49 211 216 system_nrf51.o 54 File(s) 5 976 260 bytes 2 Dir(s) 6 610 763 776 bytes free
    C:\Keil\ARM\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_hrs\arm_build>
  • Hi
  • Hi
  • I have updated to the same version that you are running, but I cannot reproduce this on my computer. Checking the KEil forums, it seems that there are other people that have this issue, but no obvious fix has been posted to any of the threads I looked at.
    Can you please .zip the ble_app_hrs project so I can run it on my computer?
    Best regards Håkon
