I am trying to create a windows app that will read data from an accerometer via a nrF8001 ble module.are there any example i can see for communication between windows and nrf8001?
See the Master Control Panel App,
64bit : www.nordicsemi.com/.../61817449
32bit: www.nordicsemi.com/.../45529553
You can log the data on Windows. You need nrf51 USB dongle.
How to use Master Control Panel Application: developer.mbed.org/.../
If you want to created a windows application yourself, then when you install Master Control Panel, I mentioned above then, there are windows example installed as well, which you can use as a base to create you own application to read data etc.
Examples are installed in : \Master Emulator\Examples
Please accept it as answer , if it works for you ;)
