nrf51822 Button Pull Up
Hi, I am working my way through the Nan 36 document and everything seems to be working fine. Have a question regarding Button Pullup.
Little confused on this piece of code:
static app_button_cfg_t buttons[] =
    {WAKEUP_BUTTON_PIN,       false, NRF_GPIO_PIN_PULLUP, NULL},
    {LEDBUTTON_BUTTON_PIN_NO, false, NRF_GPIO_PIN_PULLUP, button_event_handler},
I understand it to be that pull up would be enabled on the buttons. Which I thought it means when I press the button 01 is sent and then set to 00. So that when I press the button the second time the value is again 01. But currently I have to press the button the second time to set to 00 and then the third time to 01.
Could someone please explain it better ?
  • Hi John,
    The example works in the way that it stores the last state of the button in function "button_event_handler()". See variable "send_push".
    This means that each time you press the button, the button event handler will execute, send the "send_push" variable to the ble_lbs-handler, then invert the state of "send_push".
    This way you will get '0' first, then '1', then '0', and so on.
    Best regards Håkon
