Hi all,
I was looking into using a PWM for LED dimming, and in an attempt to smooth out transitions between light states, I found that there was visible flicker as the internal LED value was quantized to the 0-100% PWM duty cycle.
Fortunately, since the PWM duty cycle was implemented as a uint16_t, I was able to change the following lines to improve PWM resolution -
uint32_t app_pwm_channel_duty_set(app_pwm_t const * const p_instance,
uint8_t channel, app_pwm_duty_t duty)
uint32_t ticks = (nrf_drv_timer_capture_get(p_instance->p_timer,
(nrf_timer_cc_channel_t) PWM_MAIN_CC_CHANNEL) * (uint32_t)duty) / **1000UL**;
return app_pwm_channel_pulsewidth_ticks_set(p_instance, channel, ticks);
app_pwm_duty_t app_pwm_channel_duty_get(app_pwm_t const * const p_instance, uint8_t channel)
uint32_t value = (nrf_drv_timer_capture_get(p_instance->p_timer,
(nrf_timer_cc_channel_t)(channel)) * **1000UL**) \
/ nrf_drv_timer_capture_get(p_instance->p_timer,
(nrf_timer_cc_channel_t) PWM_MAIN_CC_CHANNEL);
return (app_pwm_duty_t)value;
While this works for my application, I was wondering -
- Are there any technical reasons why the duty cycle was limited to 0-100 while the allocated space was 16bit (and then casted to 32bit anyway?) Seems like one would use a uint8_t then.
- Was it removed to solve any errata I am missing?
- If none of the above, would it be possible to implement maybe a PWM units enumeration to allow someone to use a higher-resolution PWM duty? I would prefer to avoid using a modified SDK.
Thanks, -Alex
