When i setup DEVICE_MANAGER_MAX_BONDS in 2 and trying to connect third device the nRF 51422 (10028) is freezing and all LED's light up. Why the algorithm in "device_manager_evt_handler" does't work?
What error code are you getting?
After bonding third device nRF51422 stoped on "while(loop)" in function "__WEAK void app_error_handler()" in app_error.c files with the m_error_code == 0x00008010 in the debuging mode.
Hi, please read out the line number and file name as well.
\SDK\components\libraries\util\app_error.c in line 84 (while(loop))
Thank you very much for you good support...For enhancement this example i want to write in bond table devices which i want (for example, when the button is pressed before the connecting/bonding with needed device) only. Other devices should not storing in my device (without press the button), how it possible with this example?
