Hi Guys,
I am using a the 350Mhz Analog Oscilloscope HM303-6 www.hameg.com/hm303-6.0.html to measure the voltage utilised by the board when it is transmitting data.
I have cut SB9 soldered a resistor of 10 ohms on R6. I am hving some difficulty with the settings for the oscilloscope.
I connected the probes to the nrf current measurement points, with their corresonding clips to the group . And the other side of the probes to input channel 1 and 2.
There are a bunch of settings on the oscilloscope which I am not sure of. I am getting both channel 1 and 2 as two separate signals . Shouldnt there be only one signal?
And I am confused about the settings for
- X-Y does both signals qualify for a x-y mode?
- For the input channels, it should be AC enabled, gnd disabled right?
- I have enabled Dual channnel with ADD IS that correct?
- Is there any documentation for any settings for the oscilloscope?
Sorry for the noob questions. Could someone perhaps help me with some?
Thanks a lot
