I tried changing the broadcast name which was not easy but after installing the nRFgoStudio and editing the XML file with it - I managed to change the name yet the UART program no longer works . I verified this issue comparing the original "ublue_setup.gen.out.txt file with the same file re-compiles and they are different . I am assuming this makes the UART Arduino program stop working properly . After the re-compilation using "run_me_compile_xml_to_nRF8001_setup.bat" I get this error: ACI Evt Pipe Error: Pipe #:4 Pipe Error Code: 0x96
I have no idea where to find the meaning of this code .
The command suggested to rename the broadcast name does not work (even in the example it is commented out and when removing the comment it fails to compile): // Set your BLE Shield name here, max. length 10 //ble_set_name("TEST";);
Chat:39: error: 'ble_set_name' was not declared in this scope
I guess these are all maturity issues with the BLE but I can't express enough the complexity of the BLE HW/SW compared to standard BT which I wish I could use with the iPhone .
Any help would be appreciated.
