Hi everyone, Just a brief introduction about my system, I am currently working on Brain computer Interface which was funded by NSF. In our system we have Sense electronics which will provide 10k samples/sec on each of 8 channels. I Integrated micro-esc to our system firmware. I have some questions regarding micro-esc,
There is this parameter called payload_length in general RF parameters, I don't understand the significance of that variable. Can you explain what was the significance of Payload_length, it was pre-coded as 61 in the github code and in example code tx_payload_length is initialized as 8 for sending 5 bytes data. I don't understand in what relation we need to put tx_payload_length.
What is the maximum buffer we can initialize so that packets won't drop? For example for my system i need 256 bytes tx buffer and i initialize tx mode as manual i.e., whenever TX FIFO is non empty and radio is idle packets will sent automatically. So with how much frequency we can fill up tx buffer for data integrity and higher data rate and what is maximum timing interval where tx transaction is done?
we initialized useb_fifo_size as 8. So are there 8 tx fifos or one fifo of 8 bytes size?
