Function fds_stat never returns
Hi
I've implemented support for the FStorage and the FDS in our application. In some cases it happens, that the function "fds_stat" does not return.
The reason can be found in the subfunction "dirty_records_stat". If an invalid header is found the pointer p_rec is not increased and the while loop will never be left.
I assume that there is an increase of the pointer missing?
Regards Adrian
