Hi everyone,
I was wondering how GAP calls and events are synchronized within the SoftDevice.
Example:
// conn_handle is updated in the CONNECTED and DISCONNECTED event handlers
sd_ble_gap_connect_cancel();
if (conn_handle != BLE_CONN_HANDLE_INVALID)
sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
Considering this code is executed without interruption (e.g. on APP_PRIORITY_LOW level).
What happens if before sd_ble_gap_connect_cancel()
, a connection has already been established and the connection event is still pending in the SoftDevice event queue?
I cannot disconnect before I receive the connection ID in the CONNECTED event handler. So I cannot trigger the disconnect manually from this code location.
I know that the possibility that this scenario occurs is pretty low, but I want to create a implementation that works 100% safe/reliable by design.
Question: Will the sd_ble_gap_connect_cancel()
function implicitly detect that a connection has already been established, trigger the disconnect and remove the CONNECTED event from the queue? Or is it possible that I may still receive a connected event after this code section?
